주요 콘텐츠로 건너뛰기
Acer Aspire One 725-0845 RAM Replacement
필요한 것
  1. Acer Aspire One 725-0845 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 RAM Replacement: 2 단계, 이미지 1/3 Acer Aspire One 725-0845 RAM Replacement: 2 단계, 이미지 2/3 Acer Aspire One 725-0845 RAM Replacement: 2 단계, 이미지 3/3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 RAM Replacement, Back Plate: 3 단계, 이미지 1/3 Acer Aspire One 725-0845 RAM Replacement, Back Plate: 3 단계, 이미지 2/3 Acer Aspire One 725-0845 RAM Replacement, Back Plate: 3 단계, 이미지 3/3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 RAM Replacement, RAM: 4 단계, 이미지 1/3 Acer Aspire One 725-0845 RAM Replacement, RAM: 4 단계, 이미지 2/3 Acer Aspire One 725-0845 RAM Replacement, RAM: 4 단계, 이미지 3/3
    • Using two fingers, push the clamps away from the RAM chip, releasing it from the motherboard.
    • Carefully remove the RAM chip by pulling it out and away from the center of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John Allen
회원 가입일: 02/15/17
134 평판
안내서 1개 작성함
USF Tampa, Team 8-3, Eyestone Spring 2017 USF Tampa, Team 8-3, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G3
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 531
