주요 콘텐츠로 건너뛰기
Acer Aspire One 725-0845 Speaker Replacement
필요한 것
  1. Acer Aspire One 725-0845 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Speaker Replacement: 2 단계, 이미지 1/3 Acer Aspire One 725-0845 Speaker Replacement: 2 단계, 이미지 2/3 Acer Aspire One 725-0845 Speaker Replacement: 2 단계, 이미지 3/3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Speaker Replacement, Back Plate: 3 단계, 이미지 1/3 Acer Aspire One 725-0845 Speaker Replacement, Back Plate: 3 단계, 이미지 2/3 Acer Aspire One 725-0845 Speaker Replacement, Back Plate: 3 단계, 이미지 3/3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Speaker Replacement, Hard Drive: 4 단계, 이미지 1/2 Acer Aspire One 725-0845 Speaker Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Speaker Replacement: 5 단계, 이미지 1/1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Acer Aspire One 725-0845 Speaker Replacement, Inner Frame: 6 단계, 이미지 1/3 Acer Aspire One 725-0845 Speaker Replacement, Inner Frame: 6 단계, 이미지 2/3 Acer Aspire One 725-0845 Speaker Replacement, Inner Frame: 6 단계, 이미지 3/3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Acer Aspire One 725-0845 Speaker Replacement: 7 단계, 이미지 1/3 Acer Aspire One 725-0845 Speaker Replacement: 7 단계, 이미지 2/3 Acer Aspire One 725-0845 Speaker Replacement: 7 단계, 이미지 3/3
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Acer Aspire One 725-0845 Speaker Replacement: 8 단계, 이미지 1/3 Acer Aspire One 725-0845 Speaker Replacement: 8 단계, 이미지 2/3 Acer Aspire One 725-0845 Speaker Replacement: 8 단계, 이미지 3/3
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
  9. Acer Aspire One 725-0845 Speaker Replacement, Speaker: 9 단계, 이미지 1/2 Acer Aspire One 725-0845 Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Lift the black locks for the indicator light connections into the upward position.
    • Remove the indicator light connection by gently pulling the purple tabs away from the locks.
  10. Acer Aspire One 725-0845 Speaker Replacement: 10 단계, 이미지 1/1
    • Disconnect the speakers from the motherboard by carefully pulling the adapter away from the center of the device.
  11. Acer Aspire One 725-0845 Speaker Replacement: 11 단계, 이미지 1/1
    • Very carefully remove the speaker wire from the wiring harness.
    • Remove the speakers by lifting them up and away from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Catalfu
회원 가입일: 02/15/17
281 평판
안내서 1개 작성함
USF Tampa, Team 8-3, Eyestone Spring 2017 USF Tampa, Team 8-3, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G3
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 12
전체 시간: 559
