주요 콘텐츠로 건너뛰기
Acer Aspire One 751h-1948 Keyboard Replacement
필요한 것
  1. Acer Aspire One 751h-1948 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Close the laptop and flip it over to view the back of the laptop.
  2. Acer Aspire One 751h-1948 Keyboard Replacement: 2 단계, 이미지 1/3 Acer Aspire One 751h-1948 Keyboard Replacement: 2 단계, 이미지 2/3 Acer Aspire One 751h-1948 Keyboard Replacement: 2 단계, 이미지 3/3
    • Unlock the right side of the battery by sliding the battery lock to the right. Then slide the left lock to the left and remove the battery.
  3. Acer Aspire One 751h-1948 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 Acer Aspire One 751h-1948 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 Acer Aspire One 751h-1948 Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Use the plastic opening tool to push in each of the four clips and carefully lift the keyboard.
    • Don't lift the keyboard completely so that you don't damage the ribbon cable underneath.
  4. Acer Aspire One 751h-1948 Keyboard Replacement: 4 단계, 이미지 1/2 Acer Aspire One 751h-1948 Keyboard Replacement: 4 단계, 이미지 2/2
    • When you remove the keyboard, be careful not to damage the ribbon cable that attaches it to the motherboard.
    • Unplug the ribbon cable by gently lifting the black tab up. Then remove the cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Bolton
회원 가입일: 03/22/17
434 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S8-G2, Catania Spring 2017 UMass Dartmouth, Team S8-G2, Catania Spring 2017 회원
UMASSD-CATANIA-S17S8G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 240
