주요 콘텐츠로 건너뛰기
Acer Aspire One A150-1570 Internal Wireless Card Replacement
필요한 것
  1. Acer Aspire One A150-1570 Internal Wireless Card Replacement, Keyboard: 1 단계, 이미지 1/1
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 2 단계, 이미지 1/2 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 2 단계, 이미지 2/2
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 3 단계, 이미지 1/2 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 3 단계, 이미지 2/2
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 4 단계, 이미지 1/3 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 4 단계, 이미지 2/3 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 4 단계, 이미지 3/3
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 5 단계, 이미지 1/3 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 5 단계, 이미지 2/3 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 5 단계, 이미지 3/3
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
  6. Acer Aspire One A150-1570 Internal Wireless Card Replacement, Internal Wireless Card: 6 단계, 이미지 1/1
    • Close and flip the device over so you can have a good view of all the screws.
    • Locate and remove the three 3.9mm screws where the battery was removed from.
    • Locate and and remove the two 5.8mm screws located underneath the bumpers.
    • Locate and remove the three 5.8mm remaining screws at the top of the device.
  7. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 7 단계, 이미지 1/3 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 7 단계, 이미지 2/3 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 7 단계, 이미지 3/3
    • Flip and reopen device to where you can view the internal panel.
    • Locate the ZIF connecting the mouse panel to the motherboard.
    • Flip up the black plastic hinge and carefully pull out the ZIF connector.
  8. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 8 단계, 이미지 1/1
    • Locate and remove all five 4.7mm black screws.
    • Locate and remove the one 4.3mm silver screw.
  9. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 9 단계, 이미지 1/2 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 9 단계, 이미지 2/2
    • Pick a corner and slowly lift up the panel while running your finger underneath to pop off the seals.
    • Make sure to move slowly. You do not want to crack the plastic from being to rough or moving to fast.
  10. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 10 단계, 이미지 1/2 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 10 단계, 이미지 2/2
    • Locate the internal wireless card.
    • Remove the one 3.9mm screw holding it down.
  11. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 11 단계, 이미지 1/3 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 11 단계, 이미지 2/3 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 11 단계, 이미지 3/3
    • Carefully disconnect the black and white cable from the internal wireless card.
    • Pull the internal wireless card straight out.
결론
Briana Naranjo
회원 가입일: 10/10/16
369 평판
안내서 3개 작성하였습니다
Sam Houston State, Team 12-5, Blackburne Fall 2016 Sam Houston State, Team 12-5, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G5
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 323
