주요 콘텐츠로 건너뛰기
Acer Aspire One A150-1570 Keyboard Replacement
필요한 것
  1. Acer Aspire One A150-1570 Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire One A150-1570 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire One A150-1570 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire One A150-1570 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire One A150-1570 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire One A150-1570 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire One A150-1570 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Blue
회원 가입일: 10/10/16
124 평판
안내서 1개를 작성함
Sam Houston State, Team 12-5, Blackburne Fall 2016 Sam Houston State, Team 12-5, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G5
4 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 441
