주요 콘텐츠로 건너뛰기
Acer Aspire One A150-1672 Front-facing Camera Replacement
필요한 것
  1. Acer Aspire One A150-1672 Front-facing Camera Replacement, Front-facing Camera: 1 단계, 이미지 2개 중 1개 Acer Aspire One A150-1672 Front-facing Camera Replacement, Front-facing Camera: 1 단계, 이미지 2개 중 2개
    • With your fingers, remove 6 rubber coverings located at the edges of screen. The rubber coverings are held in place with a small amount of adhesive, but you should be able to peel them off easily.
    • There are 4 coverings on the top (circular shaped) and 2 on the bottom (half-oval shaped).
  2. Acer Aspire One A150-1672 Front-facing Camera Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire One A150-1672 Front-facing Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, unscrew the six 5.2mm screws in the places where the rubber coverings were located.
  3. Acer Aspire One A150-1672 Front-facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire One A150-1672 Front-facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the spudger between the thin gap located between the white and pink plastic casing at the top.
    • Move the spudger from the right side to the left to detach the white plastic frame from the pink plastic casing.
    • Remove the white frame by pulling it towards yourself.
    • It may take considerable force to initially slide the spudger between the white and pink parts of the casing.
  4. Acer Aspire One A150-1672 Front-facing Camera Replacement: 4 단계, 이미지 1개 중 1개
    • At the top of the display screen, pull the brown connector towards the right with your right hand while holding on to the black piece of electrical tape next to the white connector with your left hand to disconnect the two connectors from each other.
    • Gently pull the display screen towards you to more easily access the cable behind the screen.
  5. Acer Aspire One A150-1672 Front-facing Camera Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire One A150-1672 Front-facing Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Use the spudger to detach the piece of tape from the camera by sliding it between the camera and tape.
    • Pull the camera towards you to remove it.
결론
작성자
4다른 기여자 명과 함께
Connor Watkins
회원 가입일: 10/30/16
261 평판
안내서 2개를 작성함
Baylor, Team 4-3, Williams Fall 2016 Baylor, Team 4-3, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G3
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 535
