주요 콘텐츠로 건너뛰기
Acer Aspire One A150-1672 Individual Key Replacement
필요한 것
  1. Acer Aspire One A150-1672 Individual Key Replacement, Individual Key: 1 단계, 이미지 1/2 Acer Aspire One A150-1672 Individual Key Replacement, Individual Key: 1 단계, 이미지 2/2
    • To remove the keyboard, place the Blue Plastic Opening Tool at the 3 indentations above the keyboard as shown.
    • Slip the Blue Plastic Opening Tool in the space between the keyboard and the pink plastic casing and push down.
    • Pushing down on all 3 indentations should cause the keyboard to pop upwards slightly.
  2. Acer Aspire One A150-1672 Individual Key Replacement: 2 단계, 이미지 1/2 Acer Aspire One A150-1672 Individual Key Replacement: 2 단계, 이미지 2/2
    • There is a notch on the right side of the casing that blocks the keyboards ability to be removed.
    • Use the Blue Plastic opening tool and your fingers to pull up the top part of the keyboard as shown.
    • Use the Blue Plastic Opening Tool to separate the right side of the casing from the keyboard as shown.
    • After you have successfully moved the keyboard out from under the notch, pull the keyboard up.
  3. Acer Aspire One A150-1672 Individual Key Replacement: 3 단계, 이미지 1/1
    • Using the Blue Plastic Opening Tool, pull up on the keyboard connector to completely detach the keyboard from the base of the laptop.
  4. Acer Aspire One A150-1672 Individual Key Replacement: 4 단계, 이미지 1/2 Acer Aspire One A150-1672 Individual Key Replacement: 4 단계, 이미지 2/2
    • Using the Blue Plastic Opening Tool, remove the white plastic piece of your desired key.
    • Place the Blue Plastic Opening Tool on the right side of the individual key, then gently pull up to detach the clips underneath.
    • Remove the key from the hinges by sliding the key to the left.
  5. Acer Aspire One A150-1672 Individual Key Replacement: 5 단계, 이미지 1/2 Acer Aspire One A150-1672 Individual Key Replacement: 5 단계, 이미지 2/2
    • Two ends need to be unhooked. They are located at the top and bottom of the key on the right side.
    • Using the Spudger, push the small, clear-colored end of the hinge out of the hook.
  6. Acer Aspire One A150-1672 Individual Key Replacement: 6 단계, 이미지 1/2 Acer Aspire One A150-1672 Individual Key Replacement: 6 단계, 이미지 2/2
    • Using the Blue Plastic Opening Tool, push the plastic hinge to the left to detach the hinge after the ends on the right are detached.
    • Remove the plastic hinge by pulling the plastic hinge upwards.
결론
Vivianna
회원 가입일: 10/30/16
101 평판
안내서 1개 작성함
Baylor, Team 4-3, Williams Fall 2016 Baylor, Team 4-3, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 242
