주요 콘텐츠로 건너뛰기
Acer Aspire One AO756-2623 Battery Replacement
필요한 것
  1. Acer Aspire One AO756-2623 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Battery Replacement: 2 단계, 이미지 1/1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Battery Replacement: 3 단계, 이미지 1/3 Acer Aspire One AO756-2623 Battery Replacement: 3 단계, 이미지 2/3 Acer Aspire One AO756-2623 Battery Replacement: 3 단계, 이미지 3/3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Colin Rodwell
회원 가입일: 03/21/16
373 평판
안내서 3개 작성하였습니다
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 회원
CLEM-BENSON-S16S7G1
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 43
전체 시간: 3,054
