주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
A broken or dusty fan can cause many problems with a laptop such as overheating, which can lead to it spontaneously shutting down or short battery life, or a loud grinding noise . Using this guide to replace or clean out dust from the fan offers an easy solution to these problems.
부품
지정된 부품이 없습니다.
  1. Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Locate the circular slot positioned at the bottom right of the battery.
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Insert a spudger and slide the tab to the right. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible. Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Slide the back plate downward to remove it from the laptop. Slide the back plate downward to remove it from the laptop.
    • Slide the back plate downward to remove it from the laptop.
  7. Locate the eighteen 6 mm Phillips screws that are required to remove the keyboard.
    • Locate the eighteen 6 mm Phillips screws that are required to remove the keyboard.
    • Remove all screws using a Phillips #0 screwdriver.
  8. Orient the laptop to where the open screen is facing towards you.
    • Orient the laptop to where the open screen is facing towards you.
    • Slide the spuldger into the indicated crease.
    • Firmly slide spudger all the way around the laptop to pry the keyboard away from the bottom of the laptop.
    • Loud cracking noises will be heard during this step.
  9. Remove the green dotted ribbon cable by sliding it straight out of the clamp holding it in using a plastic spudger. Locate the two tabs that are holding the larger black ribbon cable in place. Remove the larger black ribbon cable by  pressing in the tabs and sliding it straight out of the clamp holding it in using a plastic spudger.
    • Remove the green dotted ribbon cable by sliding it straight out of the clamp holding it in using a plastic spudger.
    • Locate the two tabs that are holding the larger black ribbon cable in place.
    • Remove the larger black ribbon cable by pressing in the tabs and sliding it straight out of the clamp holding it in using a plastic spudger.
    • To remove the keyboard, lift the keyboard straight away from the rest of the laptop.
  10. Locate the ten 6 mm Phillips screws that connect the keyboard to the rest of the laptop and remove them with a Phillips #0 Screwdriver. Locate the four 6 mm Phillips screws hidden beneath black tape by lifting up the black tape and remove them with a Phillips #0 Screwdriver. To remove keyboard from the rest of the laptop, pull keyboard straight up.
    • Locate the ten 6 mm Phillips screws that connect the keyboard to the rest of the laptop and remove them with a Phillips #0 Screwdriver.
    • Locate the four 6 mm Phillips screws hidden beneath black tape by lifting up the black tape and remove them with a Phillips #0 Screwdriver.
    • To remove keyboard from the rest of the laptop, pull keyboard straight up.
  11. Orient laptop with open screen facing you.
    • Orient laptop with open screen facing you.
    • Peel back black tape.
  12. Orient the laptop to where the bottom of the laptop is facing upwards. Locate the port that connects the fan to the laptop.
    • Orient the laptop to where the bottom of the laptop is facing upwards.
    • Locate the port that connects the fan to the laptop.
    • Use a nylon spudger to firmly pull out the cable from the port.
    • Pull the fan straight out to remove it from the rest of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Davis Adams
회원 가입일: 2016년 03월 20일
459 평판
안내서 3개 작성하였습니다
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 회원
CLEM-BENSON-S16S7G1
4 회원들
안내서 14개 작성하였습니다
don’t know if i’ll tackle this. have had mine at least 5 yrs. heating up and shutting off now. maybe i’ll try it along with new heat sink paste and if that helps give it to my son, as i just bought a new Acer. thanks for the clear instructions.
misciagna - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 30
전체 시간: 1,450
