소개
A broken or dusty fan can cause many problems with a laptop such as overheating, which can lead to it spontaneously shutting down or short battery life, or a loud grinding noise . Using this guide to replace or clean out dust from the fan offers an easy solution to these problems.
필요한 것
Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
Locate the single 6 mm Phillips screw in the lower middle of the back plate.
Remove the screw using a Phillips #0 Screwdriver.
Slide the back plate downward to remove it from the laptop.
Locate the eighteen 6 mm Phillips screws that are required to remove the keyboard.
Remove all screws using a Phillips #0 screwdriver.
one 6mm phillips screw already removed at step 4, and one 3mm phillips screw. Rest sixteen 6mm phillips screw.
Do I take out the 3mm screw out as well?
Remove the green dotted ribbon cable by sliding it straight out of the clamp holding it in using a plastic spudger.
Locate the two tabs that are holding the larger black ribbon cable in place.
Remove the larger black ribbon cable by pressing in the tabs and sliding it straight out of the clamp holding it in using a plastic spudger.
To remove the keyboard, lift the keyboard straight away from the rest of the laptop.
Locate the ten 6 mm Phillips screws that connect the keyboard to the rest of the laptop and remove them with a Phillips #0 Screwdriver.
Locate the four 6 mm Phillips screws hidden beneath black tape by lifting up the black tape and remove them with a Phillips #0 Screwdriver.
To remove keyboard from the rest of the laptop, pull keyboard straight up.
다른 한 분이 해당 안내서를 완성하였습니다.
