주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
A dysfunctional hard drive can completely ruin the life of an otherwise functional computer; therefore, if any problems arise regarding the hard drive, it should be fixed or replaced. Removing the hard drive requires the battery and back cover to be removed and then only a few screws need to be removed to completely take out the hard drive.
  1. Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Locate the circular slot positioned at the bottom right of the battery.
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Insert a spudger and slide the tab to the right. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible. Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Slide the back plate downward to remove it from the laptop. Slide the back plate downward to remove it from the laptop.
    • Slide the back plate downward to remove it from the laptop.
  6. Locate the four  6 mm Phillips screws pictured necessary to remove the hard drive.
    • Locate the four 6 mm Phillips screws pictured necessary to remove the hard drive.
    • Remove all four of the screws using a Phillips #0 Screwdriver.
  7. Locate the two tabs that keep the hard drive ribbon cable connected to the laptop. Using a spudger, gently push in the indicated tabs.
    • Locate the two tabs that keep the hard drive ribbon cable connected to the laptop.
    • Using a spudger, gently push in the indicated tabs.
    • While holding down the tabs, slide the ribbon cable to the left to remove it from the laptop.
  8. Remove the hard drive by pulling it straight out.
    • Remove the hard drive by pulling it straight out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Colin Rodwell
회원 가입일: 2016년 03월 21일
364 평판
안내서 3개 작성하였습니다
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 회원
CLEM-BENSON-S16S7G1
4 회원들
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 21
전체 시간: 1,456
