주요 콘텐츠로 건너뛰기
Acer Aspire One AO756-2623 LCD Sceen Replacement
필요한 것
  1. Acer Aspire One AO756-2623 LCD Sceen Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 LCD Sceen Replacement: 2 단계, 이미지 1/1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 LCD Sceen Replacement: 3 단계, 이미지 1/3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 3 단계, 이미지 2/3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 3 단계, 이미지 3/3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 LCD Sceen Replacement, LCD Sceen: 4 단계, 이미지 1/1
    • Orient the laptop as shown in the picture with the open screen facing toward you.
  5. Acer Aspire One AO756-2623 LCD Sceen Replacement: 5 단계, 이미지 1/3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 5 단계, 이미지 2/3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 5 단계, 이미지 3/3
    • Insert the spudger into the indicated crease.
    • Firmly slide spudger around the edge of the entire laptop to remove the front plate of the screen.
    • Loud cracking noises from the plastic tabs separating may occur, do not worry, they are to be expected.
  6. Acer Aspire One AO756-2623 LCD Sceen Replacement: 6 단계, 이미지 1/3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 6 단계, 이미지 2/3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 6 단계, 이미지 3/3
    • Identify the four 6 mm Phillips screws that are necessary to remove the LCD screen.
    • Remove all four screws using a Phillips #0 Screwdriver.
    • Pull away the LCD screen from the back cover of the laptop without ripping the ribbon cable connecting it to the bottom of the laptop.
  7. Acer Aspire One AO756-2623 LCD Sceen Replacement: 7 단계, 이미지 1/3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 7 단계, 이미지 2/3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 7 단계, 이미지 3/3
    • Remove the tape covering the port connecting the screen to the bottom of the laptop.
    • To remove the LCD screen, gently pull the cable straight out of the screen.
    • In the first and second photos, the screen is lying face down on the keyboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Davis Adams
회원 가입일: 03/20/16
465 평판
안내서 3개 작성하였습니다
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 회원
CLEM-BENSON-S16S7G1
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Spot on! Perfect tutorial thank-you very much!
Sonia Green - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,001
