소개
A damaged WiFi module will not allow you to connect your laptop to the internet. Folow this guide and we will show you how to replace the WiFi module.
필요한 것
Power the laptop off.
Flip the laptop over and position it so the opening faces you.
Remove the rubber foot located near the opening side of the device using tweezers.
Position the computer so the opening side faces you.
Remove the tape holding the WiFi module using tweezers.
다른 한 분이 해당 안내서를 완성하였습니다.
