주요 콘텐츠로 건너뛰기
Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement
필요한 것
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: 3 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 4 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  6. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: 6 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: 6 단계, 이미지 2개 중 2개
    • The battery is installed in these pictures but should always be removed before any part replacement.
    • Remove the four 5mm Phillips #0 screws from the display hinge.
  7. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the two antenna cables from the Wi-fi card.
  8. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the display cable by pulling it down and towards you.
  9. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
    • This will allow the hinges holding the screen in place to lift up.
  10. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: 10 단계, 이미지 1개 중 1개
    • While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • The screen is now completely removed from the bottom half of the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph
회원 가입일: 01/25/18
685 평판
안내서 6개를 작성함
USF Tampa, Team S20-G1, Passmore Spring 2018 USF Tampa, Team S20-G1, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G1
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 1,812
