주요 콘텐츠로 건너뛰기
Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement
필요한 것
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove eleven 4 mm Phillips #1 screws.
    • Pull the backplate off using your fingers.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the rainbow cord out of the motherboard using the tabs on the sides.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove three 3 mm Phillips #1 screws holding down the battery.
    • Lift the top edge of the battery and pull back towards the hinges to remove the battery.
  4. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Remove two 4 mm screws holding down the metal plate using a Phillips #1 screwdriver.
    • Remove the plate using your fingers.
    • Remove four 5 mm screws holding the motherboard in place using a Phillips #1 screwdriver.
  5. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the yellow cord out from the motherboard using the sticker.
  6. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Pull both small blue ribbon cords out of the motherboard using the stickers.
  7. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Gently pull the black cord out from the motherboard.
  8. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the top cord out of the motherboard using the sticker.
  9. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Gently pull the motherboard away from the small square chip to its left.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Hanna Flores
회원 가입일: 09/20/17
149 평판
안내서 1개를 작성함
1가이드 댓글
Hello, can you please advise on how to replace the ram on this laptop
BenfromEssex - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 23
전체 시간: 1,409
