주요 콘텐츠로 건너뛰기
Acer Aspire One D150 Memory Upgrade Replacement
필요한 것
  1. Acer Aspire One D150 Memory Upgrade Replacement, Memory Upgrade: 1 단계, 이미지 1/1
    • Be sure computer is unplugged, turned off, and battery is removed.
    • Then, locate memory door and remove screw with #0 Phillips screw driver.
  2. Acer Aspire One D150 Memory Upgrade Replacement: 2 단계, 이미지 1/1
    • If needed, pry open door using knife or flat screw driver.
  3. Acer Aspire One D150 Memory Upgrade Replacement: 3 단계, 이미지 1/3 Acer Aspire One D150 Memory Upgrade Replacement: 3 단계, 이미지 2/3 Acer Aspire One D150 Memory Upgrade Replacement: 3 단계, 이미지 3/3
    • Remove plastic door to expose lone memory DIMM.
    • Press two metal clasps on both sides of the DIMM apart to allow memory module to pop up.
  4. Acer Aspire One D150 Memory Upgrade Replacement: 4 단계, 이미지 1/1
    • Head over to Newegg and buy yourself a 2gb DDR2, 667mhz laptop memory to install in your Aspire One.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Dante Bertana
회원 가입일: 05/08/10
702 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 31
전체 시간: 21,284
