주요 콘텐츠로 건너뛰기
Acer Aspire One D225-1625 Wireless Card Replacement
필요한 것
  1. Acer Aspire One D225-1625 Wireless Card Replacement, Battery: 1 단계, 이미지 1/3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: 1 단계, 이미지 2/3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: 1 단계, 이미지 3/3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D225-1625 Wireless Card Replacement: 2 단계, 이미지 1/1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 1/2 Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 2/2
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel and slide back and forth across the edge until the back gently pops off.
  4. Acer Aspire One D225-1625 Wireless Card Replacement: 4 단계, 이미지 1/2 Acer Aspire One D225-1625 Wireless Card Replacement: 4 단계, 이미지 2/2
    • Use tweezers to disconnect the black and white wires from the wireless card by pulling them up off the card.
  5. Acer Aspire One D225-1625 Wireless Card Replacement: 5 단계, 이미지 1/2 Acer Aspire One D225-1625 Wireless Card Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to unscrew the top right screw on the wireless card.
    • Pull out wireless card by sliding it out to your right.
결론
Alexander Ilibasic
회원 가입일: 01/30/20
430 평판
안내서 3개 작성하였습니다
댓글 한 개
Awesome I changed wireless card with your instruction this is a helpful 👍👍
sohil shekh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 28
전체 시간: 416
