주요 콘텐츠로 건너뛰기
Acer Aspire One D250-1151 Battery Replacement
  1. Acer Aspire One D250-1151 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the computer is unplugged, and turned off completely
    • Place the computer on a flat surface with the bottom facing you.
  2. Acer Aspire One D250-1151 Battery Replacement: 2 단계, 이미지 1/1
    • Place a finger on the small tab on the left with the lock and unlock symbols.
    • Slide this tab to the unlock position.
    • If done correctly, you should see an orange marker.
  3. Acer Aspire One D250-1151 Battery Replacement: 3 단계, 이미지 1/1
    • Place a finger on the tab in the upper right corner.
    • Slide this tab to the right and hold it in that position.
  4. Acer Aspire One D250-1151 Battery Replacement: 4 단계, 이미지 1/1
    • Place your finger on the three lines in the middle of the battery while holding the tab on the right.
  5. Acer Aspire One D250-1151 Battery Replacement: 5 단계, 이미지 1/1
    • Push forward on the battery lines while holding the tab on the right.
결론
Evan Edmunds
회원 가입일: 10/31/16
237 평판
안내서 2개 작성하였습니다
Baylor, Team 5-11, Williams Fall 2016 Baylor, Team 5-11, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G11
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 1,371
