주요 콘텐츠로 건너뛰기
Acer Aspire One D250-1151 Keyboard Key Replacement
필요한 것
  1. Acer Aspire One D250-1151 Keyboard Key Replacement, Keyboard Key: 1 단계, 이미지 1/1
    • Open the Computer so you have access to the keyboard and the screen.
  2. Acer Aspire One D250-1151 Keyboard Key Replacement: 2 단계, 이미지 1/1
    • Do not apply too much force while removing the key or the edge under the key will be pushed down, preventing replacement.
    • Use the plastic opening tool to lift the key from the right side until it comes off.
    • You will hear a pop, this is normal. In some cases the inner plastic part of the key will also come off.
  3. Acer Aspire One D250-1151 Keyboard Key Replacement: 3 단계, 이미지 1/3 Acer Aspire One D250-1151 Keyboard Key Replacement: 3 단계, 이미지 2/3 Acer Aspire One D250-1151 Keyboard Key Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to remove the plastic brackets from the keyboard.
    • Picture two and three show the correct orientation of the plastic pieces and how they are connected.
  4. Acer Aspire One D250-1151 Keyboard Key Replacement: 4 단계, 이미지 1/1
    • Remove the round piece by taking the axils of the circular piece out of the holes located in the center of the square piece.
    • Make sure the circular piece correctly fits into the rectangular piece while laying flat. If it does not do this the circular piece is facing the wrong way and will need to be removed, turned around, and reconnected.
결론
This process should work for any of the keys in the keyboard
Donny McKay
회원 가입일: 11/03/16
502 평판
안내서 4개 작성하였습니다
Baylor, Team 5-11, Williams Fall 2016 Baylor, Team 5-11, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G11
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 45
전체 시간: 4,542
