주요 콘텐츠로 건너뛰기
Acer Aspire One D255-1625 Battery Replacement
필요한 것
  1. Acer Aspire One D255-1625 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Aspire One D255-1625 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Aspire One D255-1625 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
결론
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 672
