주요 콘텐츠로 건너뛰기
Acer Aspire One D255-1625 Keyboard Replacement
필요한 것
  1. Acer Aspire One D255-1625 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Aspire One D255-1625 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Aspire One D255-1625 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
    • Use iFixit's Jimmy tool and press it into the small tabs at the top of the keyboard and lift up.
    • Do this for all five tabs at the top of the keyboard.
  4. Acer Aspire One D255-1625 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the Jimmy tool along the top of the keyboard once all tabs have been pressed in.
  5. Acer Aspire One D255-1625 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire One D255-1625 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire One D255-1625 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the keyboard forward to expose its connection.
    • Slide the small brown tab out to disconnect the keyboard.
    • Lift the keyboard away from the laptop.
    • If you see that the keyboard is not connected upon flipping, reconnect it and see if it works. If not, continue to replace the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zahria Martin
회원 가입일: 01/30/20
196 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 474
