주요 콘텐츠로 건너뛰기
Acer Aspire One D255-1625 RAM Replacement
필요한 것
  1. Acer Aspire One D255-1625 RAM Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Aspire One D255-1625 RAM Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Aspire One D255-1625 RAM Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 RAM Replacement, RAM: 3 단계, 이미지 1개 중 1개
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel until the back gently pops off.
  4. Acer Aspire One D255-1625 RAM Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire One D255-1625 RAM Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire One D255-1625 RAM Replacement: 4 단계, 이미지 3개 중 3개
    • Push the silver locking tabs on either side of the RAM card outward and the card will pop up to rest at an angle.
    • Slide the card straight out of its housing.
결론
댓글 2개
I was lazy to do it the proper way and thought this was a short cut... Sadly the author is an a*** and doesn't show that there are two screws connected to the bottom plastic base. Well I ripped them right off. The right way is to remove the key board and then unscrew the two screws after that you can pop the bottom panel.
YuraD95 - 답글
Sorry I was wrong it's not 2 screws it was 5 screws that I ripped off.
YuraD95 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 5
전체 시간: 381
