주요 콘텐츠로 건너뛰기
Acer Aspire One D255E RAM Replacement
필요한 것
  1. Acer Aspire One D255E RAM Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E RAM Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire One D255E RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E RAM Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire One D255E RAM Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire One D255E RAM Replacement: 3 단계, 이미지 3개 중 3개
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
  5. Acer Aspire One D255E RAM Replacement, Back Panel: 5 단계, 이미지 2개 중 1개 Acer Aspire One D255E RAM Replacement, Back Panel: 5 단계, 이미지 2개 중 2개
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  6. Acer Aspire One D255E RAM Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire One D255E RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  7. Acer Aspire One D255E RAM Replacement: 7 단계, 이미지 3개 중 1개 Acer Aspire One D255E RAM Replacement: 7 단계, 이미지 3개 중 2개 Acer Aspire One D255E RAM Replacement: 7 단계, 이미지 3개 중 3개
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  8. Acer Aspire One D255E RAM Replacement, RAM: 8 단계, 이미지 3개 중 1개 Acer Aspire One D255E RAM Replacement, RAM: 8 단계, 이미지 3개 중 2개 Acer Aspire One D255E RAM Replacement, RAM: 8 단계, 이미지 3개 중 3개
    • Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
    • It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brian
회원 가입일: 03/19/16
1,302 평판
안내서 5개를 작성함
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S16G8
2 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 23
지난 30일: 36
전체 시간: 4,742
