소개
The RAM on a computer is used to store temporary information for your computer to run swiftly. If you computer seems to studder or slow down it might mean that you could use an upgrade of the RAM. RAM upgrades are one of the more common upgrades in a computer unit. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
필요한 것
Using a spudger gently push the tab on the port forward then pull out the cable.
please don’t disconnect the keyboard for this job and even for HDD replacement..
it’s useless and you will complicate the life to yourself.
leartzajmi - 답글
Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
This step is not necessary. The screws do not have to be removed for RAM replacement.
Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
Here too many screws are removed. Only the 4 denoted with a circled "1" have to be removed.
just remove the 4 screws that are marked as “Door” or something similar since i don’t remember .. not all those need to be removed
leartzajmi - 답글
Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
You really don't need to do steps 2-6, if you are careful you can attack the lower case panel with just the spudger (just like you'd do from the top), and get at the ram/disk right away, instead of taking the rest of the machine apart.
다른 7명이 해당 안내서를 완성하였습니다.
