주요 콘텐츠로 건너뛰기
Acer Aspire One D255E Screen Replacement
필요한 것
  1. Acer Aspire One D255E Screen Replacement, Screen: 1 단계, 이미지 1/2 Acer Aspire One D255E Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Using a spudger remove the two screw covers on the front of the computer.
  2. Acer Aspire One D255E Screen Replacement: 2 단계, 이미지 1/2 Acer Aspire One D255E Screen Replacement: 2 단계, 이미지 2/2
    • Remove the two 1.2 mm Phillips #1 screws that were located under the screw covers.
  3. Acer Aspire One D255E Screen Replacement: 3 단계, 이미지 1/1
    • Using a spudger for assistance remove the front panel of the screen.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Screen Replacement: 4 단계, 이미지 1/3 Acer Aspire One D255E Screen Replacement: 4 단계, 이미지 2/3 Acer Aspire One D255E Screen Replacement: 4 단계, 이미지 3/3
    • Remove the eight 1.2 mm Phillips #1 screws holding on the screen.
    • There are wires connected to the screen unit. Make sure you do not attempt to pull off the screen just yet!
  5. Acer Aspire One D255E Screen Replacement: 5 단계, 이미지 1/1
    • Carefully remove the display ribbon cable from the connector.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 03/19/16
1,248 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S16G8
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 34
전체 시간: 2,118
