주요 콘텐츠로 건너뛰기
Acer Aspire One ZG5 Fan Replacement
필요한 것
  1. Acer Aspire One ZG5 Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Fan Replacement: 2 단계, 이미지 1/1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Fan Replacement: 3 단계, 이미지 1/1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Fan Replacement, Wireless Card: 4 단계, 이미지 1/1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Fan Replacement: 5 단계, 이미지 1/1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Fan Replacement: 6 단계, 이미지 1/1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Fan Replacement: 7 단계, 이미지 1/1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Fan Replacement: 8 단계, 이미지 1/1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
    mi lap NO tiene wireless card
    gustavo cordova - 답글
  9. Acer Aspire One ZG5 Fan Replacement, Keyboard: 9 단계, 이미지 1/1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Fan Replacement: 10 단계, 이미지 1/3 Acer Aspire One ZG5 Fan Replacement: 10 단계, 이미지 2/3 Acer Aspire One ZG5 Fan Replacement: 10 단계, 이미지 3/3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Fan Replacement: 11 단계, 이미지 1/2 Acer Aspire One ZG5 Fan Replacement: 11 단계, 이미지 2/2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Fan Replacement: 12 단계, 이미지 1/2 Acer Aspire One ZG5 Fan Replacement: 12 단계, 이미지 2/2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
    my keyboard ribbon face damaged. how to repair?
    musa musa - 답글
  13. Acer Aspire One ZG5 Fan Replacement, Top Case: 13 단계, 이미지 1/1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Fan Replacement: 14 단계, 이미지 1/2 Acer Aspire One ZG5 Fan Replacement: 14 단계, 이미지 2/2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Fan Replacement: 15 단계, 이미지 1/1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Fan Replacement: 16 단계, 이미지 1/3 Acer Aspire One ZG5 Fan Replacement: 16 단계, 이미지 2/3 Acer Aspire One ZG5 Fan Replacement: 16 단계, 이미지 3/3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Fan Replacement: 17 단계, 이미지 1/2 Acer Aspire One ZG5 Fan Replacement: 17 단계, 이미지 2/2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Fan Replacement: 18 단계, 이미지 1/2 Acer Aspire One ZG5 Fan Replacement: 18 단계, 이미지 2/2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Fan Replacement, Internal Wireless Card: 19 단계, 이미지 1/1
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Fan Replacement: 20 단계, 이미지 1/1
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Fan Replacement: 21 단계, 이미지 1/1
    • Gently pull the wireless card to the right and slide it out of its socket.
  22. Acer Aspire One ZG5 Fan Replacement, Motherboard: 22 단계, 이미지 1/1
    • Disconnect the display cable from the top left of the motherboard.
  23. Acer Aspire One ZG5 Fan Replacement: 23 단계, 이미지 1/2 Acer Aspire One ZG5 Fan Replacement: 23 단계, 이미지 2/2
    • Disconnect the speaker cable from its socket on the motherboard.
  24. Acer Aspire One ZG5 Fan Replacement: 24 단계, 이미지 1/1
    • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
    • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
  25. Acer Aspire One ZG5 Fan Replacement: 25 단계, 이미지 1/1
    • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
  26. Acer Aspire One ZG5 Fan Replacement: 26 단계, 이미지 1/1
    • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
    I took apart an SSD variant. At this step, there were two screws holding the SSD down, but the SSD did not come out with the main and daughter boards. Detaching the I/O cable freed the mainboard to come out with or without the daughterboard.
    unixusr - 답글
    there are 2 silver screws that need to be removed in this step your picture shows them still installed (one is located neer audio plug, the other is located neer keyboard plug) in step 27 (next step) they have been removed without mention
    Scott Riley - 답글
    I have added 1 gb of memory to my ZG5 thanks to this helpful guide. Total cost, including a spudger and a new mini screwdriver, to tackle the 00 Philips, GBP 17.57
    I fear I haven't put the trackpad connector back properly, but device works great with a wireless mouse. Very many thanks.
    John Serocold - 답글
  27. Acer Aspire One ZG5 Fan Replacement: 27 단계, 이미지 1/1
    • Lift the entire motherboard assembly out the case.
  28. Acer Aspire One ZG5 Fan Replacement, Fan: 28 단계, 이미지 1/2 Acer Aspire One ZG5 Fan Replacement, Fan: 28 단계, 이미지 2/2
    • Disconnect the fan cable from the motherboard.
    For info:
    gray wire: +5V,
    black wire: ground
    maroon wire: sense
    Robert Gf - 답글
  29. Acer Aspire One ZG5 Fan Replacement: 29 단계, 이미지 1/1
    • Remove the three 3.9mm screws using Phillips #1 screwdriver.
  30. Acer Aspire One ZG5 Fan Replacement: 30 단계, 이미지 1/1
    • Lift the fan housing from the motherboard.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Doug Gallatin
회원 가입일: 10/05/10
6,337 평판
안내서 10개 작성하였습니다
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G49
5 회원들
안내서 27개 작성하였습니다
댓글 4개
Steps 4~8 show to remove the wireless card from its access panel outside the computer, then steps 19~21 show to remove it from the inside once the case is off.
Redundant?
I drink beer - 답글
There are two wireless cards -- for that exact model it looks like bluetooth and 802.11n but different models may be different
nathan -
I couldn't ask for it to be any easier. Great job.
Ron Price - 답글
The page layout is good.well done job.thanks for providing the repairing information about Acer aspire one.it is the very interesting web page.http://djnni.com
belly william - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 50
전체 시간: 27,613
