이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Once the motherboard is out, it is relatively straight forward to get to the fan.
필요한 것
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Disconnect the two antenna cables from the right side of the wireless card.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 4개
Steps 4~8 show to remove the wireless card from its access panel outside the computer, then steps 19~21 show to remove it from the inside once the case is off.
Redundant?
There are two wireless cards -- for that exact model it looks like bluetooth and 802.11n but different models may be different
nathan -
The page layout is good.well done job.thanks for providing the repairing information about Acer aspire one.it is the very interesting web page.http://djnni.com
