주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire One ZG5 Hard Drive Replacement
필요한 것
  1. Acer Aspire One ZG5 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Hard Drive Replacement, Wireless Card: 4 단계, 이미지 1개 중 1개
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
  9. Acer Aspire One ZG5 Hard Drive Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Hard Drive Replacement: 10 단계, 이미지 3개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 10 단계, 이미지 3개 중 2개 Acer Aspire One ZG5 Hard Drive Replacement: 10 단계, 이미지 3개 중 3개
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Hard Drive Replacement: 11 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 11 단계, 이미지 2개 중 2개
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Hard Drive Replacement: 12 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 12 단계, 이미지 2개 중 2개
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  13. Acer Aspire One ZG5 Hard Drive Replacement, Top Case: 13 단계, 이미지 1개 중 1개
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Hard Drive Replacement: 14 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 14 단계, 이미지 2개 중 2개
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Hard Drive Replacement: 15 단계, 이미지 1개 중 1개
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Hard Drive Replacement: 16 단계, 이미지 3개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 16 단계, 이미지 3개 중 2개 Acer Aspire One ZG5 Hard Drive Replacement: 16 단계, 이미지 3개 중 3개
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Hard Drive Replacement: 17 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Hard Drive Replacement: 18 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 18 단계, 이미지 2개 중 2개
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Hard Drive Replacement, Internal Wireless Card: 19 단계, 이미지 1개 중 1개
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Hard Drive Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Hard Drive Replacement: 21 단계, 이미지 1개 중 1개
    • Gently pull the wireless card to the right and slide it out of its socket.
  22. Acer Aspire One ZG5 Hard Drive Replacement, Motherboard: 22 단계, 이미지 1개 중 1개
    • Disconnect the display cable from the top left of the motherboard.
  23. Acer Aspire One ZG5 Hard Drive Replacement: 23 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 23 단계, 이미지 2개 중 2개
    • Disconnect the speaker cable from its socket on the motherboard.
  24. Acer Aspire One ZG5 Hard Drive Replacement: 24 단계, 이미지 1개 중 1개
    • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
    • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
  25. Acer Aspire One ZG5 Hard Drive Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
  26. Acer Aspire One ZG5 Hard Drive Replacement: 26 단계, 이미지 1개 중 1개
    • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
  27. Acer Aspire One ZG5 Hard Drive Replacement: 27 단계, 이미지 1개 중 1개
    • Lift the entire motherboard assembly out the case.
  28. Acer Aspire One ZG5 Hard Drive Replacement, Hard Drive: 28 단계, 이미지 1개 중 1개
    • Turn the motherboard over so that the RAM is facing up.
  29. Acer Aspire One ZG5 Hard Drive Replacement: 29 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Hard Drive Replacement: 29 단계, 이미지 2개 중 2개
    • Disconnect the I/O board from the motherboard.
  30. Acer Aspire One ZG5 Hard Drive Replacement: 30 단계, 이미지 1개 중 1개
    • Remove the two 4.7 mm Phillips #0 screws that hold down the hard drive.
  31. Acer Aspire One ZG5 Hard Drive Replacement: 31 단계, 이미지 1개 중 1개
    • Pull the hard drive straight out from the motherboard.
  32. Acer Aspire One ZG5 Hard Drive Replacement: 32 단계, 이미지 1개 중 1개
    • Remove the four 3.9 mm Phillips #1 screws from the hard drive casing.
    • There are two screws on each side of the casing.
  33. Acer Aspire One ZG5 Hard Drive Replacement: 33 단계, 이미지 1개 중 1개
    • Remove the upper and lower casing from the hard drive.
결론
다른 114명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Doug Gallatin
회원 가입일: 10/05/10
6,385 평판
안내서 10개를 작성함
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G49
5 회원들
안내서 34개를 작성함
14가이드 댓글
Excellent guide. This "student" should be promoted to "instructor" right away. Many thanks.
Rudy Fernandes - 답글
This guide helped a lot with refurbishing my old ZG5. It now has a case that is not cracked, 1.5 GB memory, and a 240GB SSD. I get to put off Windows 10 for a while longer.
James Stallings - 답글
Thanks a lot! i already upgrade memory from 1 to 1.5 on my acer. But i have a question, does the aoa 150 works faster with a ssd disk? i want to try with one of 240 gb. Anyone try it?
Martiniano Vera Enrique - 답글
Not the easiest upgrade I've ever done (perhaps the most difficult, actually), but I got it done. Removing the keyboard was the trickiest step for me. Be patient. If you can work one of the corner releases, you can put a flat-blade screwdriver under the corner of the keyboard and work on the other releases (starting at the far corner, then the centre).
The other tricky problem I had was getting the little ribbon cable for the trackpad properly reconnected after completing the project. (I thought the keyboard cable would be the tricky part, but it turns out to be pretty easy.) Be patient and you'll be fine. You may want to test (with a mouse handy) before you reinsert the keyboard.
Thanks very much for this howto!
Jim MacKenzie - 답글
I had one of these little beasts that my son gave away about 6 years ago. The person he gave it to returned it to him a month later because it would not turn on. It was a case of the boot sector problem that plagues the ZG5. I performed the repair described on the Acer web site and it has been running fine ever since. After installing Linux Mint (dual boot), it was finally given away again last summer. Now it seems it is coming back to me. This might be the time to upgrade it with an SSD. Thanks for this tutorial. I will probably be making use of it over the next few weeks.
Chuck Pilger - 02/23/2017
Chuck Pilger - 답글
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 195
지난 30일: 613
전체 시간: 283,673
