주요 콘텐츠로 건너뛰기
Acer Aspire One ZG5 Internal Wireless Card Replacement
필요한 것
  1. Acer Aspire One ZG5 Internal Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Internal Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Internal Wireless Card Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Internal Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1개 중 1개
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Internal Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Internal Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Internal Wireless Card Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Internal Wireless Card Replacement: 8 단계, 이미지 1개 중 1개
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
  9. Acer Aspire One ZG5 Internal Wireless Card Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Internal Wireless Card Replacement: 10 단계, 이미지 3개 중 1개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 10 단계, 이미지 3개 중 2개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 10 단계, 이미지 3개 중 3개
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Internal Wireless Card Replacement: 11 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 11 단계, 이미지 2개 중 2개
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Internal Wireless Card Replacement: 12 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 12 단계, 이미지 2개 중 2개
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  13. Acer Aspire One ZG5 Internal Wireless Card Replacement, Top Case: 13 단계, 이미지 1개 중 1개
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Internal Wireless Card Replacement: 14 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 14 단계, 이미지 2개 중 2개
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Internal Wireless Card Replacement: 15 단계, 이미지 1개 중 1개
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Internal Wireless Card Replacement: 16 단계, 이미지 3개 중 1개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 16 단계, 이미지 3개 중 2개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 16 단계, 이미지 3개 중 3개
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Internal Wireless Card Replacement: 17 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Internal Wireless Card Replacement: 18 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Internal Wireless Card Replacement: 18 단계, 이미지 2개 중 2개
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Internal Wireless Card Replacement, Internal Wireless Card: 19 단계, 이미지 1개 중 1개
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Internal Wireless Card Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Internal Wireless Card Replacement: 21 단계, 이미지 1개 중 1개
    • Gently pull the wireless card to the right and slide it out of its socket.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Doug Gallatin
회원 가입일: 10/05/10
6,385 평판
안내서 10개를 작성함
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G49
5 회원들
안내서 34개를 작성함
1가이드 댓글
Este modelo tiene dos tarjeta de red? Es que adentro tiene una y esa donde se quita la tapita es otra?
marvoly - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 34
전체 시간: 24,942
