소개
After removing the top case, it is easy to get to the internal wireless card.
도구
부품
지정된 부품이 없습니다.
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Gently lift up the left side of the wireless card and slide the card out of its socket.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Disconnect the two antenna cables from the right side of the wireless card.
다른 4명이 해당 안내서를 완성하였습니다.
