주요 콘텐츠로 건너뛰기
Acer Aspire One ZG5 Keyboard Replacement
필요한 것
  1. Acer Aspire One ZG5 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Turn the netbook over and open the display so that the keyboard is facing you.
  5. Acer Aspire One ZG5 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire One ZG5 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire One ZG5 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  6. Acer Aspire One ZG5 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  7. Acer Aspire One ZG5 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire One ZG5 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Doug Gallatin
회원 가입일: 10/05/10
6,337 평판
안내서 10개를 작성함
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G49
5 회원들
안내서 27개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 14
전체 시간: 24,757
