주요 콘텐츠로 건너뛰기
Acer Aspire One ZG5 Speakers Replacement
필요한 것
  1. Acer Aspire One ZG5 Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Speakers Replacement: 2 단계, 이미지 1/1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Speakers Replacement: 3 단계, 이미지 1/1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Speakers Replacement, Wireless Card: 4 단계, 이미지 1/1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Speakers Replacement: 5 단계, 이미지 1/1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Speakers Replacement: 6 단계, 이미지 1/1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Speakers Replacement: 7 단계, 이미지 1/1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Speakers Replacement: 8 단계, 이미지 1/1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
  9. Acer Aspire One ZG5 Speakers Replacement, Keyboard: 9 단계, 이미지 1/1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Speakers Replacement: 10 단계, 이미지 1/3 Acer Aspire One ZG5 Speakers Replacement: 10 단계, 이미지 2/3 Acer Aspire One ZG5 Speakers Replacement: 10 단계, 이미지 3/3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Speakers Replacement: 11 단계, 이미지 1/2 Acer Aspire One ZG5 Speakers Replacement: 11 단계, 이미지 2/2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Speakers Replacement: 12 단계, 이미지 1/2 Acer Aspire One ZG5 Speakers Replacement: 12 단계, 이미지 2/2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  13. Acer Aspire One ZG5 Speakers Replacement, Top Case: 13 단계, 이미지 1/1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Speakers Replacement: 14 단계, 이미지 1/2 Acer Aspire One ZG5 Speakers Replacement: 14 단계, 이미지 2/2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Speakers Replacement: 15 단계, 이미지 1/1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Speakers Replacement: 16 단계, 이미지 1/3 Acer Aspire One ZG5 Speakers Replacement: 16 단계, 이미지 2/3 Acer Aspire One ZG5 Speakers Replacement: 16 단계, 이미지 3/3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Speakers Replacement: 17 단계, 이미지 1/2 Acer Aspire One ZG5 Speakers Replacement: 17 단계, 이미지 2/2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Speakers Replacement: 18 단계, 이미지 1/2 Acer Aspire One ZG5 Speakers Replacement: 18 단계, 이미지 2/2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Speakers Replacement, Internal Wireless Card: 19 단계, 이미지 1/1
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Speakers Replacement: 20 단계, 이미지 1/1
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Speakers Replacement: 21 단계, 이미지 1/1
    • Gently pull the wireless card to the right and slide it out of its socket.
  22. Acer Aspire One ZG5 Speakers Replacement, Motherboard: 22 단계, 이미지 1/1
    • Disconnect the display cable from the top left of the motherboard.
  23. Acer Aspire One ZG5 Speakers Replacement: 23 단계, 이미지 1/2 Acer Aspire One ZG5 Speakers Replacement: 23 단계, 이미지 2/2
    • Disconnect the speaker cable from its socket on the motherboard.
  24. Acer Aspire One ZG5 Speakers Replacement: 24 단계, 이미지 1/1
    • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
    • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
  25. Acer Aspire One ZG5 Speakers Replacement: 25 단계, 이미지 1/1
    • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
  26. Acer Aspire One ZG5 Speakers Replacement: 26 단계, 이미지 1/1
    • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
  27. Acer Aspire One ZG5 Speakers Replacement: 27 단계, 이미지 1/1
    • Lift the entire motherboard assembly out the case.
  28. Acer Aspire One ZG5 Speakers Replacement, Speakers: 28 단계, 이미지 1/2 Acer Aspire One ZG5 Speakers Replacement, Speakers: 28 단계, 이미지 2/2
    • Remove the four 3.9mm screws.
  29. Acer Aspire One ZG5 Speakers Replacement: 29 단계, 이미지 1/1
    • Pull the speakers gently away from the case or they may be damaged.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Doug Gallatin
회원 가입일: 10/05/10
6,337 평판
안내서 10개 작성하였습니다
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G49
5 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 11,040
