이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
There are screws and several cables that need to be removed before the top case will come off. The battery and the keyboard both need to be removed as well.
필요한 것
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
다른 6명이 해당 안내서를 완성하였습니다.
