소개
This is a guide that will help the user through the process of replacing a dying or failed hard drive. The problems this guide should address include but are not limited to "hard drive clicking noise, "Windows failed to load or "hard drive error."
필요한 것
Put on an anti-static wrist band, attaching the end onto a large piece of metal.
Make sure the laptop is unplugged from its charging cord.
Flip the laptop over to view the underside.
Slide the right battery lock/unlock button to unlock, sliding the tab outward to unlock.
At the same time, slide the left tab outwards while placing thumb on the grip strips of the battery and pull the battery outwards until it slides out.
Flip the device over so bottom is exposed.
Remove the three screws at the front edge of the device using a Phillips #1 screwdriver.
Unscrew the screws holding the blue casing to the motherboard using a Phillips #1 screwbit:
Eleven 2mm Phillips #1 screws
Three 2mm Phillips #1 screws
Use the plastic opening tool on the left side of device to pop off blue casing and slide along the edge to loosen the casing.
Separate the blue casing from the rest of the device.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
You’re not doing it the simplest way - after removing the screws from under the keyboard:
1) Hold the laptop in your hands so that the bottom plate is free to pop open from under the laptop.
2) Under the keyboard, in the metal part that covers the HDD it reads “DOOR RELEASE” and there is an arrow. With any tool, such as screwdriver, push the plastic part, where the arrow points, downwards and the bottom door will fall (do hold the laptop over your lap or desk so it don’t fall to the floor)
3) Now you can flip the laptop upside down and remove the HDD easily.
You’re guide is good, but it isn’t necessary to strip the laptop that much :) I think I actually found this way from Acer’s own guide for disassembling this model :)
-robsku
Jani Saksa - 답글
To remove the keyboard form the chassis, look for the 3 small tabs. There’s one right above the F8 key and one on each corner of the keyboard. You’re also not exactly putting the prying tool under the F8 key, but hooking the keyboard assy from the base of the blue portion of the chassis. I used a metal tool to get the initial grip, then used a plastic spudge to release the rest of the keyboard.
