소개
If you ever need to replace your Acer Aspire R (model R5-471T-51UN) keyboard, use this guide to help you navigate across the different elements connecting your keyboard. The instructions prepare you to unplug certain connections using tools like the Phillips #0 screwdriver and a spudger.
Step 5 asks you to be cautious in gently removing the battery of the laptop. From there, you will be asked to remove the motherboard, the fan, and finally the display brackets.
Before getting started, power off your device and disconnect from any other external connections.
필요한 것
Flip your laptop over so the bottom is facing you.
Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
Use the spudger to flip up the locking tabs on each of the four ZIF cable connectors.
Remove each of the ribbon cables from their connectors.
