주요 콘텐츠로 건너뛰기
Acer Aspire R R5-471T-51UN SSD Replacement
필요한 것
  1. Acer Aspire R R5-471T-51UN SSD Replacement, Battery: 1 단계, 이미지 1/3 Acer Aspire R R5-471T-51UN SSD Replacement, Battery: 1 단계, 이미지 2/3 Acer Aspire R R5-471T-51UN SSD Replacement, Battery: 1 단계, 이미지 3/3
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN SSD Replacement: 2 단계, 이미지 1/3 Acer Aspire R R5-471T-51UN SSD Replacement: 2 단계, 이미지 2/3 Acer Aspire R R5-471T-51UN SSD Replacement: 2 단계, 이미지 3/3
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN SSD Replacement: 3 단계, 이미지 1/2 Acer Aspire R R5-471T-51UN SSD Replacement: 3 단계, 이미지 2/2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN SSD Replacement: 4 단계, 이미지 1/3 Acer Aspire R R5-471T-51UN SSD Replacement: 4 단계, 이미지 2/3 Acer Aspire R R5-471T-51UN SSD Replacement: 4 단계, 이미지 3/3
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN SSD Replacement: 5 단계, 이미지 1/2 Acer Aspire R R5-471T-51UN SSD Replacement: 5 단계, 이미지 2/2
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
  6. Acer Aspire R R5-471T-51UN SSD Replacement, SSD: 6 단계, 이미지 1/2 Acer Aspire R R5-471T-51UN SSD Replacement, SSD: 6 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, unscrew the single 5mm screw holding the SSD in place.
  7. Acer Aspire R R5-471T-51UN SSD Replacement: 7 단계, 이미지 1/2 Acer Aspire R R5-471T-51UN SSD Replacement: 7 단계, 이미지 2/2
    • Gently pull the SSD to the left and out of the assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John Sandor
회원 가입일: 01/26/20
703 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 15
전체 시간: 840
