주요 콘텐츠로 건너뛰기
Acer Aspire R11 R3-131T-C1Z5 Battery Replacement
필요한 것
  1. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the laptop on to its front, so that the back is facing up
    • Unscrew the twelve 19.05 mm PH#0 screws.
  2. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • At the left front corner of the laptop, under the intel sticker, press the sharp end of a metal spudger between the keyboard and the back cover to pry it apart.
  3. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Connect the clip of an anti-static wrist strap to any piece of metal on the computer.
    • It is important to ground yourself to avoid static.
  4. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the large black rectangle at the bottom . This is your battery.
    • If you see that your battery is oozing or bulging, step away from the device.
    • Remove the black electric tape that is on the rainbow colored cable at the top of the battery.
    • Gently pull on the cable to disconnect.
  5. Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire R11 R3-131T-C1Z5 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 12.7 mm PH#0 screws. One of these screws is located on the top of the left side of the battery and the other is located in the top of the right side of the battery.
    • Remove the battery
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Davyd Goff
회원 가입일: 09/27/17
464 평판
안내서 4개를 작성함
2가이드 댓글
Nicely done manual, however share your thoughts, my ‘puter showed critical battery, I replaced an original AC14B3K with a Flyten AC14B8K battery and I have -0- lights/power. What are your thoughts?
S M Sendele - 답글
Concise, easy to follow instructions! Hint: make sure you remove ALL of the screws from the back, or it won’t come off
Dierdre - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 28
전체 시간: 7,441
