주요 콘텐츠로 건너뛰기
Acer Aspire R11 R3-131T-C1Z5 RAM Replacement
필요한 것
  1. Acer Aspire R11 R3-131T-C1Z5 RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire R11 R3-131T-C1Z5 RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the laptop on to its front, so that the back is facing up
    • Unscrew the twelve 19.05 mm PH#0 screws.
  2. Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • At the left front corner of the laptop, under the intel sticker, press the sharp end of a metal spudger between the keyboard and the back cover to pry it apart.
  3. Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Connect the clip of an anti-static wrist strap to any piece of metal on the computer.
    • It is important to ground yourself to avoid static.
  4. Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the large black rectangle at the bottom . This is your battery.
    • If you see that your battery is oozing or bulging, step away from the device.
    • Remove the black electric tape that is on the rainbow colored cable at the top of the battery.
    • Gently pull on the cable to disconnect.
  5. Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 12.7 mm PH#0 screws. One of these screws is located on the top of the left side of the battery and the other is located in the top of the right side of the battery.
    • Remove the battery
  6. Acer Aspire R11 R3-131T-C1Z5 RAM Replacement, RAM: 6 단계, 이미지 1개 중 1개
    • Locate the large silver rectangle to the right of the hard drive. This is where your ram is located.
  7. Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire R11 R3-131T-C1Z5 RAM Replacement: 7 단계, 이미지 2개 중 2개
    • Pull off the silver lid. Beneath, you will find a green circuit board. This is the RAM
    • Gently push the clips away from either side of the RAM card.
    • Remove the RAM
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Davyd Goff
회원 가입일: 09/27/17
464 평판
안내서 4개를 작성함
4가이드 댓글
can u remove ram without removing battery ?
mondanoken3 - 답글
no, you can’t if you don’t remove the battery you will probably get shocked if you don’t remove the battery I highly recommend removing the battery
Joel Lambert -
Thanks to this site; always a life saver
P.U. Foundation - 답글
I replace my 2GB of RAM to 4GB of RAM it’s much faster but the computer does not have an HD or SSD and my is a different model
Joel Lambert - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 2,751
