주요 콘텐츠로 건너뛰기
Acer Aspire R5-471T-52EE Motherboard Replacement
필요한 것
  1. Acer Aspire R5-471T-52EE Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Aspire R5-471T-52EE Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Motherboard Replacement: 2 단계, 이미지 1/1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove seven 3 mm screws using the Phillips #00 screwdriver.
  4. Acer Aspire R5-471T-52EE Motherboard Replacement: 4 단계, 이미지 1/1
    • Once the screws are removed, disconnect seven plugs from the motherboard.
    • Keep in mind that a majority of these wires are extremely thin and fragile. Disconnect them with light force and care.
  5. Acer Aspire R5-471T-52EE Motherboard Replacement: 5 단계, 이미지 1/1
    • Flip up the small black portion the connectors are connected to and disconnect them from the motherboard.
    • Grab the yellow piece of tape to easily remove the connection from the motherboard with nothing more than some gentle force.
    • Remove the large black ribbon wire by gently pulling on the white tab towards yourself.
    • Remove the large white ribbon wire by pulling up on the small black tab.
  6. Acer Aspire R5-471T-52EE Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the four remaining screws located on the fan using the Phillips #00 screwdriver.
결론
Arda Cetken
회원 가입일: 01/16/20
639 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 7
전체 시간: 576
