주요 콘텐츠로 건너뛰기
Acer Aspire R5-471T-52EE Screen Replacement
필요한 것
  1. Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: 1 단계, 이미지 2/2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Screen Replacement: 2 단계, 이미지 1/1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Screen Replacement, Screen: 3 단계, 이미지 1/1
    • Disconnect the three wires from the motherboard that connect to the screen.
    • Be very gentle when removing these wires as the connections with the motherboard are delicate.
  4. Acer Aspire R5-471T-52EE Screen Replacement: 4 단계, 이미지 1/1
    • Remove the eight 3mm screws on the hinges using the Phillips #1 screwdriver.
    • Now that the hinges have been unfastened, carefully separate the screen and screen casing from the other half of the computer.
  5. Acer Aspire R5-471T-52EE Screen Replacement: 5 단계, 이미지 1/2 Acer Aspire R5-471T-52EE Screen Replacement: 5 단계, 이미지 2/2
    • Using a spudger or an opening pick, pop open the case holding the screen. Follow the line where the two pieces of the case meet all around the screen.
    • Remove the display assembly from the device.
결론
To install the screen and reassemble your device, follow these instructions in reverse order.
Arda Cetken
회원 가입일: 01/16/20
639 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 354
