주요 콘텐츠로 건너뛰기
Acer Aspire R5-471T-52EE Screen Replacement
필요한 것
  1. Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Screen Replacement: 2 단계, 이미지 1개 중 1개
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Screen Replacement, Screen: 3 단계, 이미지 1개 중 1개
    • Disconnect the three wires from the motherboard that connect to the screen.
    • Be very gentle when removing these wires as the connections with the motherboard are delicate.
  4. Acer Aspire R5-471T-52EE Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the eight 3mm screws on the hinges using the Phillips #1 screwdriver.
    • Now that the hinges have been unfastened, carefully separate the screen and screen casing from the other half of the computer.
  5. Acer Aspire R5-471T-52EE Screen Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire R5-471T-52EE Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Using a spudger or an opening pick, pop open the case holding the screen. Follow the line where the two pieces of the case meet all around the screen.
    • Remove the display assembly from the device.
결론
To install the screen and reassemble your device, follow these instructions in reverse order.
작성자
2다른 기여자 명과 함께
Arda Cetken
회원 가입일: 01/16/20
639 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 510
