주요 콘텐츠로 건너뛰기
Acer Aspire R5-471T-52EE Speakers Replacement
필요한 것
  1. Acer Aspire R5-471T-52EE Speakers Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Aspire R5-471T-52EE Speakers Replacement, Back Cover: 1 단계, 이미지 2/2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Speakers Replacement: 2 단계, 이미지 1/1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Speakers Replacement, Battery: 3 단계, 이미지 1/1
    • Using your fingers, gently disconnect the battery plug from the motherboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    • Remove the battery from the device.
  4. Acer Aspire R5-471T-52EE Speakers Replacement, Speakers: 4 단계, 이미지 1/2 Acer Aspire R5-471T-52EE Speakers Replacement, Speakers: 4 단계, 이미지 2/2
    • Gently peel off all of the black take that sticks down the speaker cables.
    • Disconnect the two ribbon cables to allow the speaker cable to be removed from underneath.
    • Unplug the speaker cable from the motherboard.
    • Using a spudger, gently remove the speakers from the device.
결론
Arda Cetken
회원 가입일: 01/16/20
639 평판
안내서 6개 작성하였습니다
댓글 한 개
I want to replace my laptop speakers but I am not getting them from anywhere, please send a purchase link also if you have the same speakers. email : prdp9101.com@gmail.com
pradeep singh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 251
