주요 콘텐츠로 건너뛰기
Acer Aspire R5-571T-57Z0 Display Assembly Replacement
필요한 것
  1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
    • Unplug the cable connected to the RAM.
    • Carefully remove the battery.
  2. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: 2 단계, 이미지 1/2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: 2 단계, 이미지 2/2
    • Remove the six 4.0 mm screws from the hinges using a Phillips #00 screwdriver.
  3. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 3 단계, 이미지 1/2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 3 단계, 이미지 2/2
    • Peel back the stickers from the display cable.
  4. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 4 단계, 이미지 1/3 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 4 단계, 이미지 2/3 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 4 단계, 이미지 3/3
    • Hold back the film protecting the Wi-Fi card.
    • Disconnect the touch screen cable.
  5. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 5 단계, 이미지 1/2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 5 단계, 이미지 2/2
    • Pull back the tape covering the connectors.
    • Detach the two connectors (one black wire, one white wire).
  6. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 6 단계, 이미지 1/2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 6 단계, 이미지 2/2
    • Disconnect the touch control cable next to the black film.
  7. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 7 단계, 이미지 1/2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: 7 단계, 이미지 2/2
    • Flip over the laptop and pull back to remove the display assembly.
결론
Kevin Chen
회원 가입일: 03/23/22
133 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-2, Botvin Spring 2022 UMass Dartmouth, Team 1-2, Botvin Spring 2022 회원
UMASSD-BOTVIN-S22S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 220
