주요 콘텐츠로 건너뛰기
Acer Aspire R5-571T-57Z0 Fan Replacement
필요한 것
  1. Acer Aspire R5-571T-57Z0 Fan Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove twelve 4.0 mm screws from the back of the laptop using a Phillips #00 screwdriver.
  2. Acer Aspire R5-571T-57Z0 Fan Replacement: 2 단계, 이미지 1/2 Acer Aspire R5-571T-57Z0 Fan Replacement: 2 단계, 이미지 2/2
    • Use a nylon spudger to pry open the back of the laptop and remove it.
  3. Acer Aspire R5-571T-57Z0 Fan Replacement, Battery: 3 단계, 이미지 1/2 Acer Aspire R5-571T-57Z0 Fan Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
    • Unplug the cable connected to the RAM.
    • Carefully remove the battery.
  4. Acer Aspire R5-571T-57Z0 Fan Replacement, Fan: 4 단계, 이미지 1/3 Acer Aspire R5-571T-57Z0 Fan Replacement, Fan: 4 단계, 이미지 2/3 Acer Aspire R5-571T-57Z0 Fan Replacement, Fan: 4 단계, 이미지 3/3
    • Remove the seven 4.0 mm screws attaching the fan to the laptop using a Phillips #00 screwdriver.
  5. Acer Aspire R5-571T-57Z0 Fan Replacement: 5 단계, 이미지 1/3 Acer Aspire R5-571T-57Z0 Fan Replacement: 5 단계, 이미지 2/3 Acer Aspire R5-571T-57Z0 Fan Replacement: 5 단계, 이미지 3/3
    • Detach the fan cable from the motherboard.
    • Remove the fan from the laptop.
결론
McCord Murray
회원 가입일: 03/23/22
257 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-2, Botvin Spring 2022 UMass Dartmouth, Team 1-2, Botvin Spring 2022 회원
UMASSD-BOTVIN-S22S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 167
