주요 콘텐츠로 건너뛰기
Acer Aspire R5-571T-59DC Display Replacement
필요한 것
  1. Acer Aspire R5-571T-59DC Display Replacement, Back Cover Panel: 1 단계, 이미지 1/2 Acer Aspire R5-571T-59DC Display Replacement, Back Cover Panel: 1 단계, 이미지 2/2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Display Replacement, Battery: 2 단계, 이미지 1/3 Acer Aspire R5-571T-59DC Display Replacement, Battery: 2 단계, 이미지 2/3 Acer Aspire R5-571T-59DC Display Replacement, Battery: 2 단계, 이미지 3/3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Display Replacement, Display: 3 단계, 이미지 1/2 Acer Aspire R5-571T-59DC Display Replacement, Display: 3 단계, 이미지 2/2
    • Using a plastic opening tool, pry the back cover away from the screen.
  4. Acer Aspire R5-571T-59DC Display Replacement: 4 단계, 이미지 1/1
    • Remove the tape covering the connector cables once the screen is separated from the display board.
  5. Acer Aspire R5-571T-59DC Display Replacement: 5 단계, 이미지 1/2 Acer Aspire R5-571T-59DC Display Replacement: 5 단계, 이미지 2/2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the ribbon cables out of the sockets.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Star Matthew
회원 가입일: 01/25/18
155 평판
안내서 1개 작성함
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G2
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
I wish I found this tutorial before my fiance’ attempted to do this on his own. Now the replacement screen, albeit is not cracked, but the touch screen is pretty nonfunctional in my opinion. The corners don’t really work , sometimes it picks up my touch, sometimes it goes bonkers. The bottom corner of are bent and I’m continuously having to snap them back together. I’ve bought my laptop one year ago and I feel I already need to look into another. Any suggestions to try?? any help would be super appreciated.
Christina - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 17
전체 시간: 2,032
