주요 콘텐츠로 건너뛰기
Acer Aspire R5-571T-59DC Hard Drive Replacement
필요한 것
  1. Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: 1 단계, 이미지 1/2 Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: 1 단계, 이미지 2/2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: 2 단계, 이미지 1/3 Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: 2 단계, 이미지 2/3 Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: 2 단계, 이미지 3/3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC Hard Drive Replacement: 4 단계, 이미지 1/1
    • Lift the hard drive up and out of the laptop.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Kelly Johnston
회원 가입일: 01/25/18
600 평판
안내서 4개 작성하였습니다
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G2
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
I have bent the pins on my ZIF socket for my Aspire Laptop. Do you have the product name and number or know where I could buy a replacement part?
Samwise - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 24
전체 시간: 4,510
