주요 콘텐츠로 건너뛰기
Acer Aspire R5-571T-59DC RAM Replacement
필요한 것
  1. Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: 1 단계, 이미지 1/2 Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: 1 단계, 이미지 2/2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC RAM Replacement, RAM: 2 단계, 이미지 1/1
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  3. Acer Aspire R5-571T-59DC RAM Replacement: 3 단계, 이미지 1/3 Acer Aspire R5-571T-59DC RAM Replacement: 3 단계, 이미지 2/3 Acer Aspire R5-571T-59DC RAM Replacement: 3 단계, 이미지 3/3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kelly Johnston
회원 가입일: 01/25/18
600 평판
안내서 4개 작성하였습니다
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G2
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
How many slots for RAM does this laptop have? Is there a soldered stick in one of the slots? Thanks!
Alberto Einsteino - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 961
