주요 콘텐츠로 건너뛰기
Acer Aspire R7 AC Socket Replacement
필요한 것
  1. Acer Aspire R7 AC Socket Replacement, Cover: 1 단계, 이미지 1/1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 AC Socket Replacement: 2 단계, 이미지 1/3 Acer Aspire R7 AC Socket Replacement: 2 단계, 이미지 2/3 Acer Aspire R7 AC Socket Replacement: 2 단계, 이미지 3/3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 AC Socket Replacement: 3 단계, 이미지 1/1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 AC Socket Replacement, AC Socket: 4 단계, 이미지 1/3 Acer Aspire R7 AC Socket Replacement, AC Socket: 4 단계, 이미지 2/3 Acer Aspire R7 AC Socket Replacement, AC Socket: 4 단계, 이미지 3/3
    • Locate the AC Socket ribbon connector
    • Loosen the ribbon connector using the plastic opening tool
    • Pull the ribbon connector away from the motherboard
  5. Acer Aspire R7 AC Socket Replacement: 5 단계, 이미지 1/2 Acer Aspire R7 AC Socket Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to pry up on the yellow tabs holding the Socket in place
    • There is two sided tape holding this component to the case
    • Once the tape on the Socket is loose, pull up and away from the case to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Rodiek
회원 가입일: 01/13/15
601 평판
안내서 4개 작성하였습니다
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 10
전체 시간: 1,406
