주요 콘텐츠로 건너뛰기
Acer Aspire R7 Speakers Replacement
필요한 것
  1. Acer Aspire R7 Speakers Replacement, Cover: 1 단계, 이미지 1/1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Speakers Replacement: 2 단계, 이미지 1/3 Acer Aspire R7 Speakers Replacement: 2 단계, 이미지 2/3 Acer Aspire R7 Speakers Replacement: 2 단계, 이미지 3/3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Speakers Replacement: 3 단계, 이미지 1/1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Speakers Replacement, Speakers: 4 단계, 이미지 1/2 Acer Aspire R7 Speakers Replacement, Speakers: 4 단계, 이미지 2/2
    • Locate the clip attaching the right-side speakers to the motherboard.
    • Carefully pull on the clip until it detaches from the motherboard.
    • Use a plastic opening tool if needed.
  5. Acer Aspire R7 Speakers Replacement: 5 단계, 이미지 1/2 Acer Aspire R7 Speakers Replacement: 5 단계, 이미지 2/2
    • Remove the two 3.5mm #00 Phillips screws which hold the speaker in place.
    • Carefully lift the right-side speaker assembly away from the motherboard.
  6. Acer Aspire R7 Speakers Replacement: 6 단계, 이미지 1/2 Acer Aspire R7 Speakers Replacement: 6 단계, 이미지 2/2
    • Locate the clip attaching the left-side speakers to the motherboard.
  7. Acer Aspire R7 Speakers Replacement: 7 단계, 이미지 1/2 Acer Aspire R7 Speakers Replacement: 7 단계, 이미지 2/2
    • Carefully lift the left-side speaker assembly away from the motherboard.
결론
Andrew Rodiek
회원 가입일: 01/13/15
601 평판
안내서 4개 작성하였습니다
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 722
