주요 콘텐츠로 건너뛰기
Acer Aspire R7-572-6423 Battery Replacement
필요한 것
  1. Acer Aspire R7-572-6423 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Battery Replacement: 2 단계, 이미지 1/2 Acer Aspire R7-572-6423 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the top and middle rubber feet under the laptop to reveal hidden screws.
  3. Acer Aspire R7-572-6423 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the five 6 mm T9 screws.
    • Remove the eight 10 mm T9 screws.
  4. Acer Aspire R7-572-6423 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the back cover.
  5. Acer Aspire R7-572-6423 Battery Replacement: 5 단계, 이미지 1/1
    • Unplug the ribbon cable connecting the battery to the motherboard.
    • Be careful around the motherboard, as it is easily damaged.
  6. Acer Aspire R7-572-6423 Battery Replacement: 6 단계, 이미지 1/1
    • Remove the three 4 mm Phillips #1 screws securing the battery.
  7. Acer Aspire R7-572-6423 Battery Replacement: 7 단계, 이미지 1/2 Acer Aspire R7-572-6423 Battery Replacement: 7 단계, 이미지 2/2
    • Pull open the clips on either side of the battery to free it from the case.
    • Remove the battery from the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gavin Hill
회원 가입일: 09/12/18
318 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 1,499
